These Japanese round files perform superbly when working on internal curves or opening up holes or expanding slots.
The blade is 5mm in diameter and fitted with a comfortable textured moulded rubber grip. The cutting length is 90mm with extra fine teeth with a pitch of only 0.7mm. The total length is 200mm.
These files are ideal for carvers, cabinetmakers, musical instrument makers and sculptors. They are capable of the accurate removal of timber on difficult or awkward grained wood. Rasps produce sawdust, files make filings (dust); an Iwasaki carver’s file produces miniature shavings. Like a rasp, an Iwasaki file removes material very quickly but the resulting surface is much smoother, requiring only a little sanding to finish.
Made in Japan.
For carvers, cabinetmakers, musical instrument makers and sculptors
Leaves a surface that requires very little further finishing
Teeth are milled and chemically etched for maximum bite
Built-in chip-breakers minimise clogging
Suitable for wood, plastics and other similar materials
