Chestnut Tools 4 Piece Palette Knife Set
502371
502371
- Stainless steel blades with mirror-finish polish
- Super flexible, taper from about 1.5mm at the tang to 0.2mm at the tip
- Perfect for cutting glue into fine cracks
- Applying filler or even to paint in tight spaces
Originally made for artists, these palette knives have a home in many tool kits. The stainless steel blades have a mirror-finish polish and are super flexible. The blades taper from about 1.5mm at the tang to a mere 0.2mm at the tip. These are perfect for cutting glue into fine cracks, applying filler or even to paint in tight spaces where a brush would be too messy. Four shapes give you plenty of options. Each blade has a brass ferrule and hardwood handle. The blades range from 16 to 32mm wide.
- Blades range from 16 to 32mm wide
