Chroma Craft Rustina Metallic Paint - 236ml
- Second stage in creating the look of ancient corroded metal
- Suitable for wood, metal, ceramic, glass and plastics
- Paint contains real metal particles
Chroma Craft Rustina™ is a unique water-based system, which you can use to produce the look of ancient corroded metal on a variety of surfaces including wood, metal, ceramic, glass and plastics. Developed with Woodturner Nick Agar, this system imparts a realistic aged blue/green verdigris or a red/brown rust effect on turned objects and other items. It is a simple four stage process that only involves wielding a paintbrush.
These metallic paints are applied over the primer colour. The paint contains real metal particles. These particles react with the ageing solution when it is applied to the still wet paint, to give the appearance of aged metal. The iron paint turns a reddish brown giving a genuine looking rust effect. The bronze and copper the greenish look of old verdigris.
