DeWALT DCS355N Multi-Tool 18V & 28 Accessories (Body Only)
104116
104116
- Quick Change Accessory System for tool-free attachment change
- Brushless motor delivers up to 57% more runtime
- Dual-grip variable speed trigger for complete control
- LED light illuminates dark work surfaces for accurate cutting
- Body only machine without battery or charger
- Supplied with backing pad, 25 abrasive sheets, 2 saw blades and blade adaptor
The DeWALT DCS355N oscillating multi-tool uses the Quick-Change Accessory System allowing you to change blades and attachments without the use of tools.
The brushless motor at the heart of the tool delivers up to 57% more runtime compared to brushed motors. The dual-grip variable speed trigger provides complete control over the speed.
A bright LED light that illuminates dark work surfaces for accurate cutting. A universal accessory adaptor allows its use with most oscillating tool accessory brands.
This is a body only machine supplied with backing pad, 25 abrasive sheets, 2 saw blades and a blade adaptor.
