Easy Inlay Paua Abalone & Mother of Pearl Strips
AX1059836
AX1059836
- Paula Abalone shell is extremely colourful
- Use for adding colour to woodturning and woodworking projects
- Such as, jewellery, pens, boxes, furniture and more
- Presents opalescent blues and rich greens
- Easy to use with CA glue or epoxy
- Supplied in packs of 3
- Each strip is approximately 230 x 3.8 x 0.7 mm in size
Show more
Show less
Paua Abalone shell is extremely colourful and exhibits opalescent blues, rich greens, and luminous fiery flashes. Easy Inlay made even easier; simply peel the sticky backing off the strip, lay it into a ring groove or other channel and add resin (CA glue, UV-cure resin). Quickly and simply add colourful fire to jewellery, pens, boxes, furniture, wine stoppers, vessels, and more! Supplied in packs of 3, each strip is approximately 230 x 3.8 x 0.7 mm in size. Easy to use, apply with CA glue or epoxy.
Overall L x W x H | 230 x 3.8 x 0.7 mm |
