Easy Wood Tools Mini Easy Hollowing™ Set 3-Piece
109276
From £305.98 £254.98
Low Stock
  • Set of 3 Mini Hollowers, small hollow forms are as easy as 1, 2, 3
  • Carbide cutting tips keep an edge many times longer than HSS
  • Rectangular section shafts improve stability and minimise chatter
  • No need to sharpen; simply rotate cutter to a fresh edge
  • American Maple handle with copper ferrule for strength
Easy Wood Tools Mini Hollowing Tools are a great aid when it comes to turning items like ornaments, mini vases, and other small hollow forms. These Hollowers are designed to make turning small hollow forms easier and safer, turn with more confidence. This set of all three will give you access from just-under-the-rim to deep unseen cavities. Mini Easy Hollowing tools come fitted with a Negative Rake Solid Carbide Cutter. The negative rake minimises the risk of a catch at the same time leaving a cleaner finish. Hollowing is as Easy as 1 - 2 - 3.
The Mini-size Easy Hollower #1 is used to remove the bulk of the material from the middle of the hollow form.
The #2 Mini-size Easy Hollower has a gently curved shaft allowing you to begin hollowing to the side and start undercutting.
The Mini-size #3 Easy Hollower has a pronounced curve, which allows you greater access when undercutting deep inside the hollow form. All three tools have 8m square section shafts providing excellent stability when sitting on your lathe’s tool rest.
Easy Wood Tools’ replaceable carbide cutting tips keep an edge many, many times longer than HSS. When the edge eventually dulls; simply slacken the fixing screw and turn to a fresh edge.
The 305mm long handles are straight grained American Maple, with copper ferrules for strength. Their overall length is 380mm.
3 1
