From £197.98 £164.98
Low Stock
  • Hollower #2; gently curved shaft to begin undercutting
  • 12.7mm x 25mm shaft provides 200mm reach
  • Carbide cutter keeps its edge many, many times longer than HSS
Customers Also Bought
Easy to turn. Easy to own.
100% Made in America
Easy Wood Tools were the first company to develop replaceable carbide-tipped turning tools for professional woodturners and hobbyists back in 2008. The company makes the tools in their headquarters in Kentucky and the carbide tips in their own manufacturing plant in Illinois. This gives them complete control over development and quality of their products.
What makes them 'Easy'?
Square section bar
This unique design ensures the tool sits flat and steady on the tool rest, making it safer and easier to use. No need to learn specific bevels or cutting angles to make your cuts, simply hold the tool and move it left or right to rough out, smooth or create coves or beads.
No need to sharpen
Each tool features a carbide cutter which keeps an edge at least ten times longer than HSS (High Speed Steel). When an edge eventually becomes dull, simply slacken the fixing screw, turn to a fresh edge and go again.
Pick your project
Easy Wood Tools offer a range of different size tools to ensure you have a tool perfect for your project. Within each range the tools have different coloured handles for quick and easy recognition.
Use these tools to turn dry or green wood; they equally work well on very hard woods, acrylics and resins. The negative rake tips work particularly well on acrylics, polyester and resins, and produce a smooth finish on timber.
Hollow forms can be tricky, Easy Wood Tools hollowers make this branch of turning easier and safer. Turn hollow forms with confidence, Easy Hollowing tools are designed to give you access from just-under-the-rim to deep unseen cavities. Hollowing is as Easy as 1 - 2 - 3.
The Mid-size Easy Hollower #2 has a gently curved shaft allowing you to begin hollowing to the side and start undercutting. It comes fitted with a Solid Carbide cutting tip. Easy Wood Tools’ carbide keeps an edge many, many times longer than HSS. When the edge eventually dulls; simply slacken the fixing screw and turn to a fresh edge. The 12.7mm deep by 25mm wide rectangular section shaft provides excellent stability and gives the #2 hollower a reach of 200mm.
The 508mm long handle is straight grained American Maple, with a copper ferrule for strength. The overall length is 749mm.
The shaft is engraved with the corresponding carbide cutter reference number.
  • Rectangular section shaft improves stability and minimises chatter
  • No need to sharpen; simply rotate cutter to a fresh edge
  • American Maple handle with copper ferrule for strength
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolTrade AccountSaving tag iconDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
