You can use Everbuild 502 all-purpose, weatherproof adhesive for all your wood to wood bonding requirements. 502 is a high quality, resin-based wood adhesive for internal or external use.
Once cured it forms a strong, impact-resistant bond that in normal conditions is stronger than the wood itself. Everbuild 502 dries clear, any excess squeeze out can be cleaned with a damp cloth. The adhesive cues rapidly with an initial setting time of 10 minutes, clamping is recommended until fully cured.
An environmentally-friendly, water based wood glue 502 is suitable for all general woodworking and joinery uses and furniture assembly. It has a high degree of water resistance (if used externally overpainting is recommended).
Conforms to the international standard EN 204 (D3) and BS 14256 for creep resistance.
Weatherproof adhesive for all wood to wood bonding
Strong bond, stronger than the wood itself
Rapid cure, initial set in just 10 minutes
Environmentally friendly, clean-up with damp cloth
