FEIN AMM 700 MAX TOP AS MultiMaster AMPshare 18V (Body Only)
109543
From £289.98 £241.65
Low Stock
  • Cut, saw, sand, rasp, scrape, polish, grind and more
  • Kit includes 60 accessories
  • AMPshare battery compatibility with Bosch 18V and others
Customers Also Bought
AMPShare is a multi-brand battery system offering the flexibility to switch between tools and brands with compatible batteries. AMPShare batteries make it easy for you to use 18V tools from different brands using the same battery. AMPshare technology is based on the Bosch Professional 18V System and now includes many leading European brands and is growing. AMPShare batteries are fully compatible with all tools within this multi-brand alliance including Bosch Professional 18V tools and chargers all the way back to 2008.
The FEIN AMM 700 MAX TOP AS MultiMaster can cut, saw, sand, rasp, scrape, polish, grind and more. A vast range and variety of accessories allow you to perform tasks and access places other power tools cannot. This powerful professional machine offers outstanding performance under heavy work loads. This multi-tool takes the complete range of Starlock, Starlock Plus and Starlock Max accessories.The FEIN AMM 700 MAX TOP AS MultiMaster offers even more versatility thanks to the AMPshare battery compatibility.
This kit version comes with 60 accessories to get you started. Its brushless PowerDrive motor offers a long maintenance free service life. With variable speed and constant speed under load, you have complete control whatever the task or the material. Tool changes could not be quicker or easier with FEIN’s QuickIN system; three seconds is all it takes. The anti-vibration system provides long fatigue free working whilst noise insulation helps protect your hearing. This is a tough tool built to last with an all-metal gearbox. Electronic Cell Protection (ECP), protects the battery against overload, overheating and total discharge and an electronic safety cut-off protects you and the saw should the blade jam, for example.
Supplied with:
2 x E-Cut standard saw blades curved (35 mm)
2 x E-Cut standard saw blades curved (65 mm)
1 x E-Cut precision saw blade (35 mm)
1 x E-Cut precision saw blade (65 mm)
1 x E-Cut long-life saw blade (10 mm)
2 x E-Cut long-life saw blades (35 mm)
1 x E-Cut long-life saw blade (32 mm)
1 x E-Cut long-life saw blade (42 mm)
1 x E-Cut carbide Pro saw blade (32 mm)
1 x Segmented saw blade (Ø 85 mm)
1 x HSS segment saw blade
1 x HM rasp (triangular)
1 x Scraper blade
1 x Cutter blade, mushroom shaped
1 x Multi-function knife
1 x Sanding plate with holes
40 x Sanding sheets (10 of each grit 60, 80, 120 & 180)
1 x Dust extraction outlet
1 x L-Boxx 136 storage case
Note this is a body only tool supplied without batteries or charger.
  • Powerful professional machine with outstanding performance
  • Designed for continuous use with high workloads
  • Brushless motor offers extended runtimes
  • Constant electronic speed control with variable speed dial
  • Takes all Starlock, Starlock Plus and Starlock Max accessories
Benefits
  • Includes 36 month machine guarantee
  • Full repair, free of charge
  • Replaced in the event of theft
  • Original parts guaranteed
  • 14 day money back
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolTrade AccountSaving tag iconDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
