FEIN MultiMaster Finger Sanding Pad (Starlock) (Pkt 2)
508751
This product is no longer available online or by phone. Unfortunately we are unlikely to receive any more stock.
50mm long by 36mm wide for sanding hard to reach spots
Supplied in a pack of 2, uses hook and loop backed abrasives
Starlock mounting for fast work progress and precise results
Compatible with all Oscillating Multi-Tools using the OIS fitting system; FEIN MultiMaster, FEIN MultiTalent, Bosch GOP, Bosch PMF, AEG, Hitachi, Einhell, Makita, Metabo, Milwaukee, Ryobi, Skil, Dremel and others. DeWALT Oscillating Multi-Tools will require an adapter
50mm long by 36mm wide, the finger shape reaches the parts other sanding pads cannot. Supplied in a pack of two, the pad has a hook and loop facing for attaching the abrasive.
The FEIN Starlock (patented) oscillating multi-tool mounting system overcomes the disadvantages found with previous designs. Starlock sets the new standard in the oscillating multi-tool market. The design greatly improves the transmission of torque from the motor to the blade tip. No more wasted power, means faster working, minimised vibration and better results. Starlock accessories are compatible with all OIS and OIS-compatible power tools currently on the market. Looking rather like a crown bottle top, the raised portion of the Starlock snaps into the next generation of multi-tools, making the system truly tool-less.
