A tool for all trades. The FEIN MultiMaster MM 500 Plus TOP is a powerful mains powered MultiTool. Without a doubt it will provide a solution to a myriad of problem tasks especially when it comes to remodelling, renovation work and any interior alterations. It is a must have tool for virtually any trade or home owner.
The MM 500 Plus TOP takes the complete range of Starlock and Starlock Plus accessories and is compatible with many older multitool accessories. The StarlockPlus tool mounting system is tool-less allowing you to make changes in under 3 seconds. Starlock Plus offers rigidity with 100% power transmission. Starlock and Starlock Plus accessories are available to cut, saw, sand, rasp, scrape, polish and grind.
MM 500’s Anti-vibration system significantly reduces vibration and noise. The 350W motor with its infinitely variable speed control supplies plenty of power, for working in a wide variety of applications and materials. An all metal gearbox withstands high loading and gives you outstanding service life.
The combination of the oscillating movement and huge range of accessories makes this a true 'MultiMaster' of all trades. It is perfect for the professional user, home renovator and all types of general work.
The MM 500 Plus TOP comes in a robust case along with a dust extraction adaptor, 5 x E-Cut long-life saw blades, 1 x carbide Pro saw blade, 1 x 75mm carbide saw blade, 1x carbide rasp (triangular), 1 x scraper blade, 1 x sanding pad, and 20 x sanding sheets.
Registration is required within 6 weeks of purchase.
Fein offer a 3 year warranty, registration required and this must be completed within 6 weeks of the tool purchase date.
For more information and to register your product visit the Fein website
