Festool CTM 26 E CLEANTEC Dust Extractor (M class)
- M Class dry extraction, filters dust as fine as 0.1 mg/m³
- Compatible with Bluetooth control module (optional accessory)
- Integrated power tool socket with auto on/off
- 3.5m smooth anti-static hose improves extraction efficiency
- Hose glides easily will not snag on edges
- CLEANTEC bayonet fitting ensures secure tool connection
- SELFCLEAN filter bags ensure 100% capacity is used
- Top T-LOC dock for Systainer cases
- Braked swivel castor wheels
The "M" class CTM 26 E filters 99.9% of hazardous dust with limit values greater than 0.1 mg/m³ for a safer, healthy and clean working environment. A flow sensor monitors the air speed and issues a warning if the airspeed falls below of 20 m/sec.
Dust extractors class M are suitable for vacuuming/extracting dry, non-combustible dusts, non-combustible liquids, wood dusts and hazardous dusts with STELs >0.1mg/m³.
The power tool socket has an automatic on/off switch. Once connected the extractor automatically starts when you switch your tool on. On release of the tool’s trigger, the extractor continues to run for a few seconds to clear any remaining dust before automatically switching off. The machine’s control panel includes provision for retrofitting the Bluetooth control module (or the compressed air module or EAA module).
The CTM 26 E comes with 3.5m of smooth anti-static hose, greatly improving efficiency. Reduced internal friction increases the airflow rate and therefore the suction power. The smooth outer skin means you no longer need worry about ribbed hose snagging on edges. A CLEANTEC bayonet fitting ensures a secure connection to your power tool and a quick disconnection.
The top of the machine features storage space for the hose and a T-LOC compatible dock allowing SYSTAINER cases to lock and stack onto the top of the extractor. Swivel castors and rear wheels offer excellent mobility and an integrated locking brake guarantees a firm stance when working.
To the rear of the machine is a unique cable storage holder, with a folding mechanism. This lets you simply remove the cable when you want to use the machine, rather than waste time unwinding it. The compact high performance turbine motor ensures constantly strong suction. Step-less speed adjustment, allows you to select the correct power for the task in hand. The machine has a removable main filter for easy cleaning and maintenance A wet filter is available for wet pick-up. The 26-litre container holds a SELFCLEAN filter collection bag, this minimises clogging, resulting in constant maximum suction and ensuring 100% of the bag is utilised.
Supplied with SELFCLEAN filter bag, 3.5m smooth suction hose, hose holder, Sys-Dock with T-LOC function and cable holder. Robust, reliable, safe and durable, Festool dust extractors offer dust-free working conditions in combination with both electrical and pneumatic machines.
