Festool DOMINO DF 500 Q-Set Jointing Machine
- Unique 230V jointing system using DOMINO® shaped wooden dowels
- Patented routing principle with a wide range of adjustment options
- Stop positions for hole centres 16, 20, 22, 25, 28 and 40mm
- Depth stops at 12, 15, 20, 25 and 28mm
- Set version supplied with D5 cutter, support bracket, trim stop
- Cross stop and Systainer T-LOC case SYS3 M187
Festool DOMINO DF 500 & DF 700 Dowel - 10 x 50mm (Pkt 510)From £99.98 £83.32
The 'DOMINO' is a unique jointing system using rounded loose tenons to join timber giving very strong accurate and precise joints. Combining exceptional versatility with simple handling for maximum precision, the DOMINO has a patented routing principle with a wide range of adjustment options to make it extremely easy to use. The machine's fence can be adjusted to cut slots centrally in 5 pre-set timber thicknesses and manually adjusted for other thicknesses. The dowels can be placed centrally, offset, in pairs or groups. There are retractable stops for accurate positioning from the edge of the work piece. The jointer fence can be adjusted to 5 pre-set angles and is also infinitely variable between 0 and 90°. There are 6 different sizes of DOMINO available.
Various accessories increase the versatility of the DOMINO: Support bracket which is a simple right angle bracket that attaches to the base of the Domino with two thumb screws, this can be used to add surface area to the face of the DOMINO to increase stability during use. Trim stop to help align narrow wooden strips between 22 and 70mm centrally, plus it can also be used for mitre cuts. Cross stop, which is used for repeat hole spacing between 100 and 205mm without the need for marking the work. Handrail fence and DF-stop for reducing dowel centre from 37 to 20mm.
Supplied as a set version complete with: D5 cutter, support bracket, trim stop, cross stop and Cross stop and Systainer T-LOC case SYS3 M187.
Benefits
- Includes 36 month machine guarantee
- Full repair, free of charge
- Replaced in the event of theft
- Original parts guaranteed
- 14 day money back
Corded or Cordless | Corded |
Cutter Depth Stops | 12, 15, 20, 25 and 28 mm |
Cutter Speed | 24,300 rpm |
Domino Cutter Sizes | 8, 10, 12 and 14 mm |
Domino Sizes | 4 mm x 20 mm to 10 mm x 50 mm |
EAN Barcode | 4014549081426 |
Height Adjustment | 5 mm to 30 mm |
Manufacturer Part Number | 574429 |
Mitre Angle Range | 0° - 90° |
Model | DF 500 Q-Set |
Motor Power | 420 W |
Movable Stepped Stops | 16, 20, 22, 25, 28, 36 & 40 mm |
Nett Weight | 3.2 kg |
Plug Fitted | UK 3 pin plug |
Rating | Trade/Professional |
Sound Power Level LwA [Uncertainty K] | 95 dB(A) [3.0 dB] |
Sound Pressure Level LpA [Uncertainty K] | 84 dB(A) [3.0 dB] |
Vibration Cutting Wood [Uncertainty K] | 3.0 m/s² [1.5 m/s²] |
Voltage | 230 V |
