From £597.98 £498.32
Low Stock
  • Very versatile router and trimmer
  • Interchangeable router bases
  • Simple easy guiding and handling in either mode
Customers Also Bought
Known as a module edge router by Festool, this is a very versatile tool with interchangeable bases to widen its uses and ensure very positive handling and accuracy. Just by handling this tool you will see the advantage of the bases being easily interchangeable, and how simple handling and guiding the cutter is, as well as the adjustability. The standard base can be used with or without the side fence. The motor being in the vertical position allows for a wide range of hand routing, guiding the router where needed. With the extended trimming base fitted, the motor is in a horizontal position. The cutter is then guided by the bearing assembly to give extremely accurate trimming of solid edges and laminates, with pressure applied exactly where needed. Extraction outlets are fitted on the bases as well as the fence for optimum extraction. The 720W motor has an electronic speed adjustment switch to ensure maximum power and speed selection depending on material and cutter. The motor also has a temperature monitor for long service life.
Supplied as a set in a SYS3 M 237 case with the following accessories: 1/4" and 8mm collets, parallel side fence with fine adjuster and extraction hood, 1.5° router table trimming base and bearing follower, tarnishing pad and extraction hood.
  • Routing solid wood, acrylic, PVC edge veneer etc
  • Motor temperature monitor for a long service life
  • Electronic speed selector
  • Supplied as a set with accessories:
  • Side fence with fine adjuster and extraction hood
  • 1.5 Degree base and bearing follower
  • Extraction hood, tarnish pad and SYS3 M 237
Benefits
  • Includes 36 month machine guarantee
  • Full repair, free of charge
  • Replaced in the event of theft
  • Original parts guaranteed
  • 14 day money back
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTickA tick symbolTrade AccountSaving tag iconDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
    4.50 8
