Festool MFT/3 Multifunctional Table Basic
508565
508565
- Multi-functional sturdy work table
- Suitable for work holding whilst cutting, shaping and sanding
- MDF work surface 1,157 x 773 mm
- Perforated with 20mm holes ready to take accessories
This multi-functional work table can be turned into a very versatile work surface and folded away after if space is at a premium. The MDF top is perforated over its entire surface with 20mm holes to take a range of accessory clamps, rails and stops to hold, cut and machine work accurately. Due to the amount of position available for clamps and stop it can be easily be adapted to take regular and irregular shaped workpieces up to 78mm thick and 700mm wide. Overall table size 1,157 x 773mm, Table height 900mm (with legs folded 180mm), Load capacity 120kg and weight 28kg. Supplied as basic version without accessory clamps and rails.
- Part of the Festool MFT system
- All shaped workpieces up to 78mm thick and 700mm wide
- Legs fold for ease of transport or storage
- Supplied without accessory clamps and rails
- Table height 900mm (with legs folded 180mm)
- Load capacity 120kg and weight 28kg
