Festool Mixed Impact Bit Set + Holder BT-IMPSORT1
107005
107005
- 5 high quality 25mm bits for commonly used screws
- Practical, well chosen impact screwdriver bit set
- Includes 1/4" hex magnetic bit holder
- Reinforced torsion zone for long service life
- Easy access thanks to well designed BitBOX
- 1 x each T20, T25, T30 and T40 plus 1 x Pz2
With this completely practical and carefully chosen bit set, the chances are you will always have the bit you need. These 5 high quality impact screwdriver bits fit the screw head recesses most commonly encountered in general use. The bits are extra robust with a reinforced torsion zone, which ensures a longer service life.
The thoughtfully designed BitBOX stores the bits neatly ensuring they are easily accessible. In addition, the BitBOX has a rear clip for attaching it to a belt or trouser pocket. The set contains a 1/4" Hex magnetic bit holder plus 1 x each T20, T25, T30 and T40 plus 1 x Pz2.
