Festool TSC 55 KEB Plunge Saw & 1,400mm Guide Rail 18V (Body Only)
- An unbeatable combination for perfectly straight cuts
- 18V or 36V power, fitted with 1.8mm thin kerf blade
- Performs at up to twice the speed of previous models
A new and improved Festool plunge saw
Brand new features enhance the performance of the tool and make your life easier.
Safe
The new and unique kickback stop is an innovative addition to the TSC 55 KEB, reducing risk of accidents by stopping the blade immediately when sawing or plunging into the workpiece. If triggered, the saw can be used again straight away and no parts need to be replaced.
Efficient
A combination of a new, thin kerf 1.8mm blade, impressive torque and 18V battery power allows the TSC 55 KEB to perform at up to twice the speed of previous models.
Cordless
The TSC 55 KEB is completely cordless, powered by a dual 18V battery system and a brushless EC-TEC motor. These features ensure the product is as powerful as a mains tool.
Precise
The angle and depth settings allow you to select the perfect position for your workpiece, you can even set up your saw to make undercuts. Fully interchangeable with Festool guide rail systems, allowing virtual splinter free accurate cuts on both sides.
Easy to use
Festool's FastFix system has been incorporated into the TSC 55 KEB, ensuring blade changes can be completed in a few easy steps. Once the blade is changed, the sawing speed adapts to the material.
Healthy
Efficient extraction when attached to Festool's adapted system using an extractor with Bluetooth automatic switch on, or with a dust bag.
Festool Rail Bag with Shoulder Strap For Rails up to 1,400mmFrom £79.88 £66.57
Festool TCT Saw Blade Thin Kerf Laminate - 160mm x 1.8mm x 20mm 52TFrom £88.78 £73.98
The Festool TSC 55 KEB plunge saw teamed up with a Festool 1,400mm guide rail. An unbeatable combination when it comes to perfectly straight cuts and overall performance. The saw runs on either one or two 18V batteries and uses a 1.8mm kerf blade. With both batteries and the narrow kerf it performs at up to twice the speed of previous models.
A unique kickback stop protects you and your workpiece. It minimises the risk from kickbacks when plunge cutting, stopping the blade in the blink of an eye. The brushless EC-TEC motor combined with two batteries makes the TSC as powerful as a mains-powered machine.
Dust control is into a collection bag or connection to a suitable extractor via Bluetooth® for virtually dust-free work.
A transparent viewing window gives a good view for the start and finish of a plunge cut. A detachable splinter guard in front of the blade, offers a virtually splinter-free finish on both sides of the work. Angle adjustment from -1° to 47° allows a slight undercut for perfect butt joints. The cut line remains the same no matter what the cutting angle. The slimline housing allows you to make cuts as close as 12mm.
Supplied with 42 tooth thin kerf blade and Systainer SYS3 M 337 carry case. Part of the Festool 18V family of tools.
This is a body only tool supplied without a battery or charger.
Benefits
- Includes 36 month machine guarantee
- Full repair, free of charge
- Replaced in the event of theft
- Original parts guaranteed
- 14 day money back
Batteries Included | Body Only Tool |
Battery Type | Li-ion |
Battery Voltage | 36 V (2 x 18 V) |
Bevel Angle Range | -1° to +47° |
Blade Diameter | 160 mm |
Bore Size | 20 mm |
Corded or Cordless | Cordless |
Dust Extraction | 27 mm / 36 mm Outlet |
EAN Barcode | 5052511126149 |
Kerf | 1.8 mm |
Max Depth of Cut @ 45º | 43 mm |
Max Depth of Cut @ 90º | 55 mm |
Model | TSC 55 KEB |
Nett Weight | 4.6 kg (18V) / 5.3 kg (36V) |
Rating | Trade/Professional |
Saw Blade Speed | 2,650 - 3,800 rpm (with 1 x 18V batt) 2,650 - 5,200 rpm (with 2 x 18V batt) |
Sound Power Level LwA [Uncertainty K] | 106 dB(A) [5.0 dB] |
Sound Pressure Level LpA [Uncertainty K] | 95 dB(A) [5.0 dB] |
Spindle Lock | Standard Feature |
Vibration Cutting Wood [Uncertainty K] | 2.5 m/s² [1.5 m/s²] |
