FISCH Auger Bits 1/4" Hex Shank
From £12.68 £10.57
  5. Half Star
3 Reviews
  • 1/4" hex shanks fit quick change chucks and keyless chucks
  • 235mm long, ground from one piece for strength
  • Excellent waste clearance, quick cutting, made in Austria
235 mm long auger bits of the highest quality, made by FISCH in Austria. They feature 1/4" hex shanks enabling you to use them in a 1/4" hex quick change chuck or for a non slip grip in a keyless drill chuck. Suitable for soft and hard wood. A deep gullet rapidly clears the waste and the threaded tip helps pull the auger into the timber for a fast, clean cut. The auger bit is ground out of one piece of steel to ensure precision with high accuracy to give a long working life. Shanks tempered to DIN 3126-E6,3.
4.70 3
