FISCH Black Shark Forstner Cutter
From £14.98 £12.48
  5. Half Star
17 Reviews
  • Drill splinter-free holes in hardwood and softwood
  • 10 times faster than conventional forstner bits in hardwood
  • Wave edge design gives 25% increase in performance
  • Drilling requires less effort, produces superior results
  • Large chip-free zones ensure perfect chip discharge
  • For tear-free accurate flat bottomed holes every time
  • Flats on shank for secure grip in drill chuck
  • Forged from one piece of high quality tool steel for extra strength
  • Working length 60mm, overall length 90mm
  • 15, 20, 25 and 30mm: shank 8 mm
  • 35, 40, 45, 50 and 60mm; shank 10mm
  • Made in Austria, Europe
  • Show More
Forged in Austria, these Forstner bits produce smooth, splinter-free holes in hardwoods and softwoods. These bits will give you tear-free, accurate, flat bottomed, blind and even overlapping holes with perfectly smooth sides every time. They drill faster and require less effort that any comparable bit. The shanks of the bits have three flats for a secure grip in a drill chuck. They work 10 times faster than conventional forstner bits in hardwood. Forged from one piece of high quality tool steel for extra strength, the reason behind the increased performance is the FISCH Wave Cutter technology. This unique design significantly reduces friction at the cutting rim with excellent chip removal.
Black Shark Wave forstners differ from the standard wave cutters with a shorter centre point and the wave edge is more aggressive and similar to a saw tooth forstner, it is modelled on a Sharkskin. The design ensures fast, smooth cutting with considerably less friction and resistance as well as less heat generated even when drilling at high speeds. Fast cutting ensures will not only save time, but will save battery life when it comes to cordless drilling. Ideally suited to hardwoods.
The shank is coated so that it is corrosion resistant, whilst the periphery cutting edge is polished.
Working length 60mm, overall length 90mm.
15, 20, 25 and 30mm options: shank 8 mm.
35, 40, 45, 50 and 60mm options: shank 10mm.
4.60 17
