Freud’s industrial circular saw blades are designed for cutting solid wood, wooden panels and manmade boards. The blades are designed to deliver; high performance, a quality finish and longevity.
The superior performance of these saw blades comes from several unique features. Silver I.C.E, is a specifically engineered coating that is heat resistant and protects against resin build-up and corrosion. Anti-vibration slots offer a flawless finish, stabilising the blade and reducing chatter. Expansion slots dissipate blade stress and reduce noise. Each blade type within the range uses a specific grade of freud’s own Hi-Density Carbide; matched to the blades intended use. This carbide enables the carbide teeth on Freud's blades to last up to four times longer than standard products.
These blades deliver outstanding finishing even under extreme working conditions.
