This 2Qt Pressure Pot Assembly Kit has everything you need to benefit from the increased capacity using your 4-stage Fuji Spray HVLP System. The 2Qt Pressure Pot Assembly offers several advantages. The 2.25L capacity is twice as much as a standard and three times that of a gravity fed gun. You can spray larger areas without refilling. There is now little weight for you to carry and manipulate so spraying is less tiring for your arm and wrist. Without an attached pot the spray gun will fit into smaller places and is able to spray at any angle, even upside down.
Please note, you will need both a standard 25ft hose plus a 2049F Whip Hose in order to us your Fuji Spray 2Qt Pressure Pot.
If using model 9600-G – GXPC Spray Gun, you will also need the 9060 L-Fitting (Order code 103702)
Supplied with 2Qt pressure pot plus adaptor, 1,800mm material fluid hose, quick-connect coupler, pressure tube and check valve and nipple caps
