Fuji Spray Mini-Mite 3 Platinum Turbine Unit
951679
From £444.98 £370.82
  5. Half Star
2 Reviews
Low Stock - Ready to dispatch
  • Three stage turbine power unit
  • Heat Dissipation Box results in much cooler running
  • Most finishes can be sprayed
  • 25' (7.6m) 3/4" hose supplied
  • Supplied with Fuji's comprehensive guide
The Fuji Mini-Mite 3 Platinum system is an upgraded version of the Mini-Mite 3. It has a three stage turbine power unit, 7.6m (25') of 3/4" bore hose and now incorporates the Fuji Heat Dissipation Box (HDB) found on the top of the range Platinum models. The HDB expels excess heat from the turbine resulting in much cooler operating temperatures and longer motor life. It is similar in most respects to the Q3 model but without the cost of the Q3's noise deadening package. Despite this, the Mini-Mite 3 Platinum is really as quiet as any comparable HVLP system on the market. Most finishes can be sprayed, including inks, stains, lacquers, varnishes, enamels, acrylics and so on, although some will have to be thinned before use. Included with the unit is Fuji's very comprehensive guide which covers all aspects of HVLP spraying in great detail. Spray gun is not included.
It is essential equipment is cleaned after every job and operating instructions are followed. Failure to do so will void warranty
Warranty 2 Year Warranty
4.50 2
