Fuji Spray Mini-Mite 4 Platinum Turbine Unit
951680
From £651.98 £543.32
2 Reviews
In Stock - Ready to dispatch
  • Quiet running powerful four stage 8psi turbine power unit
  • Heat Dissipation Box results in much cooler running
  • Low air delivery pressure gives good finish with reduced overspray
  • All known coatings can be sprayed, some may require thinning
  • Choice of 2 superb quality Xpc non-bleed spray guns
  • Supplied with 1.4mm aircap, others sizes available
The Fuji Mini-Mite 4 Platinum system is an upgraded version of the Mini-Mite 4. It features a powerful four stage 8psi turbine unit and now incorporates the Fuji Heat Dissipation Box (HDB) found on the top of the range Platinum models. The HDB expels excess heat from the turbine resulting in much cooler operating temperatures and longer motor life. It is similar in most respects to the Q4 model but without the cost of the Q4's noise deadening package. Despite this, the Mini-Mite 4 Platinum is really as quiet as any comparable HVLP system on the market. All known coatings can be sprayed, including inks, stains, lacquers, varnishes, enamels, acrylics and so on, although some will have to be thinned before use. Included with the unit is Fuji's very comprehensive guide which covers all aspects of HVLP spraying in great detail. There is a choice of spray guns, spray gun is not included.
It is essential equipment is cleaned after every job and operating instructions are followed. Failure to do so will void warranty
Warranty 2 Year Warranty
4.00 2
