Fuji Spray Q4 Platinum Turbine Unit & G-Xpc Gravity Spray Gun
717842
From £1,359.96 £1,133.30
Low Stock
  • Package deal comprises the Fuji Spray Q4 Platinum Turbine Unit with the G-Xpc gravity feed spray gun.
  • Quiet running, powerful four stage 8psi turbine power unit
  • Heat Dissipation Box results in much cooler running
  • 7.6m(25') of 3/4" bore hose supplied
  • Low air delivery pressure gives good finish with reduced overspray
  • All known finishes can be sprayed, some may require thinning
  • Superb quality spray gun
  • Supplied with 1.4mm aircap, others sizes available
  • Fuji Spray Guns
  • Professional G-Xpc spray gun features spray fan pattern control
  • Spray fan pattern from 3mm up to 30mm in diameter
  • 100% stainless steel fluid components, no 'O' rings used
  • Non-Bleed spray gun for less turbulence of the workshop air
  • High-Efficiency 1.4mm air cap installed for even less over spray
  • Four other sizes of air caps available, spray all known coatings
  • Show More
The Fuji Spray Q4 Platinum system is an upgraded version of the Gold Pro. It consists of a powerful four stage turbine power unit fitted with Fuji's unique quiet technology like the Gold, but now also incorporates the Fuji Heat Dissipation Box (HDB) found on the top of the range platinum models. The HDB expels excess heat from the turbine resulting in much cooler operating temperatures and longer motor life. For contractors spraying latex house paints this machine is a perfect choice. The air delivery pressure is low but also slightly warmed, which means an excellent finish can be achieved without the mess and wastage which usually results from excessive overspray. All known coatings can be sprayed, including inks, stains, lacquers, varnishes, enamels, acrylics and so on, although some will have to be thinned before use. Included with the unit is Fuji's very comprehensive guide which covers all aspects of HVLP spraying in great detail. 7.6m(25') of 3/4" bore hose is supplied.
Fuji Spray G-Xpc spray gun
The Fuji Spray G-Xpc Gravity Spray Gun features a spray fan control knob to adjust the size of the fan from 3mm up to 300mm and any size in-between. The pattern control knob allows you to adjust to the exact size of the object you are spraying. A 400cc pressurised gravity cup has the Fuji tilt feature, allowing you to spray in any direction including upwards. 100% stainless fluid components, stainless springs, metal knobs and collar, an ergonomic handle that is always cool to the touch. 1.4mm Aircap Set is installed - perfect size for most fine finishing with lacquers, polyurethanes, latex, water based coatings and others.
Warranty 2 Year Warranty
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolTrade AccountSaving tag iconDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
