GemRed Electronic Digital Caliper - 155mm/6"
952910
From £34.18 £28.48
  5. Half Star
40 Reviews
  • Buy 5 for £30.76 £25.63 each
  • Buy 10 for £29.05 £24.21 each
  • Buy 20 for £27.34 £22.78 each
In Stock - Ready to dispatch
  • Robust stainless steel construction
  • High precision digital readout
  • Imperial or metric display at the touch of a button
  • Measures external, internal, step and depth
  • Zero to 155mm or 6" by 0.01mm or 0.001"
This high precision digital readout caliper has a very robust all stainless steel construction. Use for internal, external, step and depth measurements. Accuracy is 0.01mm or 0.001" and maximum measuring distance 155mm or 6". Zero can be set at any point along the range, and the display is easily switched from a metric to an imperial reading. It takes a standard SR44 battery (supplied). N.B. Philips 00 screwdriver required for battery compartment.
4.40 40
