GripIt Curtain Kit
106507
GripIt Curtain Kit
106507
This product is no longer available online or by phone. Unfortunately we are unlikely to receive any more stock.
- Gripit Curtain Kit holds up to 71kg
- 6 x Gripit yellow plasterboard fixings
- 1 x Gripit 15mm flat bit, 6 x 25mm screws
Show more
Show less
Whether it’s your finest nets or your thickest velvet curtains, using this kit you can confidently secure the curtain track or pole to a plasterboard wall. With all 6 fixings in place, they will support up to 71kg, so even the heaviest curtains won’t be a problem.
Gripit is a unique method of fixing an item to a plasterboard wall. Gripit fixings distribute the load over a much wider area compared to conventional fixings or plugs. Gripit is one of the strongest plasterboard fixings available.
The Gripit Curtain Kit contains 6 x Gripit yellow plasterboard fixings, 6 x 4 x 25mm screws and a Gripit 15mm flat bit.
#AxminsterTools
