Use this Gripit kit to hang a mirror or your precious works of art on a plasterboard wall.
Supplied with hanging hooks, these fixings are capable of supporting even the heaviest gilded frame (maximum recommended load 20kg on a single hook). Gripit is a unique method of fixing an item to a plasterboard wall. Gripit fixings distribute the load over a much wider area compared to conventional fixings or plugs. Gripit is one of the strongest plasterboard fixings available.
The Gripit Mirror Kit contains 2 Gripit red plasterboard fixings, 2 screws (5 x 30mm), 2 heavy duty hooks and a Gripit 18mm flat bit.
