Cabineo is a one-piece connector, designed to join cabinet panels and other panel furniture elements. The Cabineo connector offers many advantages in the manufacture of cabinets. Its design means it can be machined on all CNC machines, including 3-axis machines, nesting machines and CNC routers.
The Cabineo connector fits into a drilled or routed recess, which is machined solely from the surface. The machining process saves a great deal of time as there is no additional edge drilling required. Compared with a cam and dowel, the Cabineo connector offers more efficient machining and faster assembly. The body of the Cabineo connector is a glass-fibre reinforced moulding; it is simply tapped into its recess.
Pre-installing the connectors does away with the need to pick and ship a separate bag of fixings. Cabinets can be shipped flat-packed complete with connectors, simplifying final assembly.
Cabineo 8 M6 offers all the existing advantages of the Cabineo, such as the surface machining, flat-pack delivery and quick assembly. In addition, Cabineo 8 M6 offers more application possibilities.
Cabineo 8 M6, allows you to create connections in materials like aluminium, steel or HPL. Where the thread cannot be cut directly into the substrate, Lamello offers an insert for an even stronger joint. This insert is ideal for detachable corner and dividing panel joints with a heavy load. Ideal for high quality removable furniture, modular parts or trade fair construction.
The strength can be further improved. The Lamello inserts are hammered into the dividing panels with a through hole, into which the Cabineo then engages from both sides. This generates an enormous clamping force. Another plus point is the simplified assembly; whether this is a corner connection or a dividing panel joint, the Cabineo 8 is always used with the corresponding insert nut (Cabineo insert nut M6x12.3 for 16mm material thickness and Cabineo insert nut M6x15.3 for 19mm material thickness).
Cabineo 8 M6 for connections in wide variety of materials
Efficient machining and faster assembly
Surface machining, no edge drilling necessary
Cabinets shipped flat-packed with connectors pre-installed
