From £107.88 £89.90
  • Unique fitting to overcome many design problems
  • Clamps, locking joint in place and is also detachable
  • No glue or screws are required, simple assembly
Customers Also Bought
Book your demonstration
Lamello products are renowned for their precision and quality, saving you time and money with outstanding results. Our knowledgeable and friendly team are available to demonstrate the Lamello range in person or via a video call. You can see the tools in use and ask questions before placing your order.
Part of the Lamello Zeta range of connectors, the P-10 is small for connecting 13mm panels. Designed to overcome many design assembly problems, this clamping connector is almost totally invisible with only a single 6mm hole showing on the finished joint. The P-10 is biscuit in shape with a special 'T' profile, one side is fitted with a pivot lever and two alignment studs, this can then be clamped to the other mating piece and locked. The lever is driven using a hexagon key though the 6mm hole. The pocket for the P-10 needs to be cut with a Lamello Zeta machine specially developed for this application, cutting the slot and adding the 'T' to the bottom using a unique vertical mechanical drive. Once cut, the connector simply slides in place, no screws or glue are needed. Made from fibreglass reinforced plastic for strength. Overall length is 52mm x width 19mm, each half has a depth of 9.7mm, it is 7mm in width (9.7mm o/a with 'T'). Requires P-10 drill guide.
  • Only visible sign of joint is a single 6mm hole
  • Special 'T' slot needs to be cut by Lamello Zeta biscuit jointer
  • For 13mm panels size 52 x 19 x 9.7mm
  • Made from fibreglass reinforced plastic for strength
  • Suitable for solid wood, composite boards and other sheet materials
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTickA tick symbolTrade AccountSaving tag iconDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
