Lamello Classic X Biscuit Jointer in Case 850W 230V
108358
From £669.98 £558.32
2 Reviews
  • Swiss made, precision 850W biscuit jointer
  • Depth adjuster with preset cutting depths
  • CNC machined base for accurate and easy alignment
Book your demonstration
Lamello products are renowned for their precision and quality, saving you time and money with outstanding results. Our knowledgeable and friendly team are available to demonstrate the Lamello range in person or via a video call. You can see the tools in use and ask questions before placing your order.
Lamello is the home of the original biscuit jointer, invented over sixty years ago. As with all of this company's products, precision and constant development is the key. The latest Swiss made Classic X features a more powerful 850W motor as well as lighter weight and a slimmer body.
CNC machined fences for accurate alignment, allow you to take full advantage of biscuit jointing connectors; glued, self-clamping or knock-down.
The main feature of the Classic X is the accuracy and the ease of setting for height, depth and angle. The multifunctional stop square gives greater stability when working vertically, allows variable height positioning and instantly aligns 22.5° and 45° angles. The swivelling base can be set at any point between 0 - 90° (22.5°, 45°, 67.5° and 90°) and used with or without the stop square for angle locations. With this fence mounted on the fixed base and the swivel set at 90°, a very secure platform is established for narrow edge work. Scales on both the angle and height adjustment are in metric. A very clear central marker is embossed into the baseplate. There is a choice of six preset depths for the common biscuit/connector sizes with further fine adjustable if required. The body of the machine is slim with a positive ‘D’ handle for the best grip.
The machine is supplied in a Systainer case with a 36mm suction stub, stop square, 4mm spacer, tool set and manual.
Warranty Lamello 2 Year Warranty
Lamello Trade 3 Year Guarantee
A 2 year warranty applies to all Lamello devices; no registration required.
5.00 2
