Lamello Invis Mx2 Studs
506237
506237
Out of Stock
- Use with Mx2 connector
- 30mm gives stronger hold in materials like particle boards
- MX2 is the latest connector, 250kg of clamping force,
- Hard nickel surface, stud has deeper set thread to make threading easier
- Pack of 20
Show more
Show less
These are part of the range of accessories and connectors for the Lamello Invis Mx system. The latest Mx2 Invis connector gives 250kg of clamping force and has a hard nickel surface for a high quality look. This stud has a deeper set thread making the threading of the screw easier. Use with Mx2 connector. This 30mm version will give a stronger hold in materials like particle boards and is especially suitable for jointing worktops. Pack of 20.
#AxminsterTools
