Lamello products are renowned for their precision and quality, saving you time and money with outstanding results. Our knowledgeable and friendly team are available to demonstrate the Lamello range in person or via a video call. You can see the tools in use and ask questions before placing your order.
The TOP21 features a height adjustable blade for greater precision. This has to be the ultimate in biscuit jointing from the inventors of the biscuit jointer Lamello. Precise in every way, it is very easy to set cutter and fences for exact placement on your work. The cutter can be adjusted for height as well as having 6 preset depth settings. The fences on the TOP21 are flush on the sides for easier positioning; the angle stop/extending front fence is for mitre joints 0-90° with indents 22.5°, 45°, 67.5°and 90°, the square fence stop is used for stability and runs parallel, locking squarely with a quick lever. The soft start 800W electronic motor has no fall off in speed irrespective of the load, the plunge action is extremely smooth and the blade has scoring teeth for the cleanest cutting action. Overall this has to be the ultimate jointer available today. Supplied with, dust bag, dust extraction connectors (23 and 36mm), 4mm slip-on plate, tool kit and Systainer case.
3 years' extended guarantee exclusively on this Lamello Biscuit Joiner. Product must be registered on the Lamello website within 30 days of purchase. Applies to selected countries.
A 2 year warranty applies to all Lamello devices; no registration required.
