The Mafell S25M Wet and Dry Dust Extractor fully complies with M class extraction regulations. It captures 99.9% of dust and is entirely suitable for industrial and commercial purposes. Lightweight and highly efficient, the S25M has smooth startup and automatic run on when switched off, to ensure the hose is clear. The suction power can be varied to suit the debris being collected or the hose diameter being used. A power take off allows you to connect and extract from a power tool of up to 1,400W. The S25M will start automatically when you switch the power tool on and then shut off after a few seconds run when the tool is switched off. The top of the extractor features an adapter plate (MAX holder) that will hold any systainer power tool case or L-BOXX. Bypass cooling by the high performance motor fan helps ensure a long, trouble free service life.
Dust extractors class M are suitable for vacuuming/extracting dry, non-combustible dusts, non-combustible liquids, wood dusts and hazardous dusts with STELs >0.1mg/m<³.
Supplied with:
4m anti-static extraction hose 27mm diameter with bayonet lock, 35mm hose connector, Filter cassette, Non-woven filter bag and MAX-holder for Systainer/L-BOXX cases.
