Makita DJV180Z Cordless Jigsaw 18V (Body Only)
- Compact and light in weight design
- Tool-less blade change and LED worklight
- Maximum cut in wood 135mm
- Variable trigger, 3-stage pendulum action
- Tilting base plate for bevel cuts
- Li-Ion technology to give high power and performance
- Makita 'star' technology compatibility
- Part of Makita 18V Li-Ion family
- Supplied as body only
The Makita 18V jigsaw is part of the 18V Li-Ion family and has all the advantages of Li-Ion along with tool-less blade change, variable speed trigger, job light and a well balanced body with rubber grips for added comfort. The machine is supplied as jigsaw body only without batteries case or charger.
Manufactured in the UK, at the Makita factory in Telford.
Please note: model number starting with letter 'D' has a 'star' imprint on the connector plate enabling full communication with a Makita battery also with a 'star'.
The warranty period of your Makita tool may be extended to an additional 2 years subject to the following conditions:
- Makita Tools that are CE marked and (with the exceptions of Batteries, Battery Chargers, Accessories, Petrol Products, Production Tools and Air Tools and Compressors) purchased on or after 1st July 2012.
- The tool is registered by the end user within 30 days of purchase.
For more information and to register your product visit the Makita website.
N.B. Batteries and chargers 1 year warranty. For machines purchased in the UK but then exported, the standard 2 year warranty would apply.
Batteries Included | Body Only Tool |
Battery Type | Li-ion |
Battery Voltage | 18 V |
Corded or Cordless | Cordless |
EAN Barcode | 088381662710 |
Max Depth of Cut Steel | 10 mm |
Max Depth of Cut Wood | 135 mm |
Model | DJV180Z |
Nett Weight | 2.8 kg |
Pendulum Action | Standard Feature |
Rating | Trade/Professional |
Sound Power Level LwA [Uncertainty K] | 95 dB(A) [3.0 dB] |
Sound Pressure Level LpA [Uncertainty K] | 84 dB(A) [3.0 dB] |
Stroke Length | 26 mm |
Stroke Rate | 0 - 2,600 /min |
Tilting Base | Standard Feature |
Vibration Cutting Chipboard [Uncertainty K] | 8.0 m/s² [1.5 m/s²] |
Vibration Cutting Sheet Metal [Uncertainty K] | 3.5 m/s² [1.5 m/s²] |
