Compact router trimmer that combines one motor with different bases. This machine is great for a host of small routing and trimming tasks in the workshop or on site. The motor is fitted with variable speed control and has a soft start. It can be quickly interchanged and locked into the required base. This kit comes complete with three bases; Plunge, Trimming and Bevel.
Plunge base: turns the machine into a plunge router with 2 solid grip handles, a height adjuster with fine adjustment and a stepped turret for repetitive depth setting. The side fence fits left or right. Easy to control, suitable for decorative edge working as well as small mortices and grooves.
Trimming base: this small 90mm round base turns the machine into a trimmer for single handed use. Use with or without the height adjustable bearing guide for cutters without bearings, rolling on the curve for a fine cut. A trimmer guide is supplied for curved work or the side fence can be used for straight work.
Bevel base: a small square 90mm base that can tilt and be locked at a required angle (45°-0°-30°), allows for more scope when profiling and jointing.
In addition the machine is supplied with a 1/4" collet (The RT0702 will accept a 3/8" collet not supplied), Side fence, Trimmer guide, 16mm & 10mm template guides, side grip handle (can replace right plunge base handle), dust extraction set, 13 and 22mm wrenches and tool bag.
Note: This router is fitted with an Anti Restart Safety Switch and is incompatible with a seperate external NVR switch.
One motor with 3 different bases: plunge, trimming and bevel
Host of small routing and trimming tasks in the workshop or on site
Motor is fitted with variable speed control, soft start
Can be quickly locked into the required base
Plunge base: 2 solid grip handles, quick and fine height adjuster
Trimming base for single handed use, fitted with bearing guide
Bevel base can tilt and be locked at a required angle
Trimming guide with roller bearing for curved edge work
The machine is also supplied with a 1/4"collet, side fence, 16mm & 10mm template guides, side grip, dust extraction shrouds, 13 and 22mm wrenches and tool bag.
