Mirka DEOS II 663CV Delta Sander Deco Solution Kit
- Perfect solution for sanding into corners and tight areas
- High performance 300W brushless motor
- LED speed indicators to easily adjust variable sanding speed
- Compact, low profile machine easy to use in any position
- 3mm orbit for fast material removal
- Exceptionally low vibration levels for increased comfort
- Pad size 100mm x 152mm x 152mm
The pointed pad of the Delta sanders give them easy access into corners and tight spots. The DEOS II 663CV takes things further with a compact, low profile, lightweight body, the perfect sanding solution even for an extended period. It is perfect for woodwork and decorative painting, and is ideal for use on doors and windows, corners, edges and tight spaces.
When it comes to those tight spots, the DEOS II 663CV is unrivalled. It makes sanding jobs faster, easier and more comfortable than ever before, especially when working on vertical areas. The 3mm orbit diameter and powerful, upgraded 300W brushless motor makes it the perfect tool for effective and fast stock removal. There is variable speed control ranging from 5,000 - 10,000 rpm, and the design makes it easy for the operator to change. LED indicators are located on the speed selector, together with a separate on/off switch and lockable speed for optimum control.
The low weight and exceptionally low vibration levels allow prolonged use without the prospect of aching muscles and tired shoulders. You can monitor vibration levels, in real-time with an enhanced Bluetooth connection to the myMirka app.
The use of Mirka's Abranet net abrasive and direct connection to a suitable extractor offers virtual dust-free sanding and minimal time spent cleaning up.
The 663CV delta sander comes with a Mirka Deco Solutions kit containing:
25 x Abranet® ACE HD sheets in grit P80
25 x Abranet® ACE HD sheets in grit P120
50 x Abranet ® sheets in grit P180
Registration is required within 30 days of purchase.
The Mirka 2+1 year warranty applies to Mirka sanders, dust extractors and polishers. If a problem occurs with a Mirka tool caused by a manufacturing defect material or by workmanship; Mirka will repair your tool free of charge in accordance with the warranty terms.
Registration is required within 30 days of purchase. More information can be found on the Mirka warranty website and in the warranty conditions.
For warranty issues outside of the UK, tools must be returned to the UK and carriage charges would be at the customer's own cost.
Register your product nowCable Length | 4.3 m |
Corded or Cordless | Corded |
Dust Extraction | 27 mm Outlet |
EAN Barcode | 6416868519716 |
Model | DEOS II 663CV |
Motor Power | 300 W |
Nett Weight | 0.97kg |
No Load Speed | 5,000 - 10,000 rpm |
Orbit Diameter | 3.0 mm |
Pad Size | 100 mm x 152 mm x 152 mm Delta |
Plug Fitted | UK 3 pin plug |
Rating | Trade/Professional |
Sound Power Level LwA [Uncertainty K] | 79 dB(A) [3.0 dB] |
Sound Pressure Level LpA [Uncertainty K] | 68 dB(A) [3.0 dB] |
Vibration Sanding [Uncertainty K] | 2.6 m/s² [1.5 m/s²] |
Voltage | 230 V |
