Mirka DEROS 5650CV Random Sander Solution Kit with Abranet ACE & Hose
- DEROS package includes DEROS sander, 200 Abranet® ACE discs and extraction hose
- Features an integrated vibration sensor and Bluetooth low energy technology
- Unique brushless high performance motor
Customers Also Bought
This package includes the compact DEROS sander with 200 Abranet® ACE abrasive discs and anti-static extraction hose.
The DEROS has to be the most compact random orbit sander on the market today. It is supplied with both 125mm and 150mm pads that can be simply swapped over. The body of the machine houses a unique brushless motor with motor control technology. With its small body and low weight of just 1kg, it is perfect for all prolonged use in almost any position - flat, overhead or vertical.
The control and smoothness is excellent with the motor giving constant speed even under load; it is fitted with soft start and electronic brake. You can switch the machine on, then control speed with the variable lever on top of the machine. Speed range covers 4,000 - 10,000rpm and the 350W high performance brushless motor is comparable to a standard 500W motor. The DEROS also features a closed construction so that no dust can enter the machine causing wear. The power cord is exchangeable.
The 125mm and 150mm backing pads can be exchanged quickly to suit your application; both pads have a universal hole pattern to enable the fitting of many different makes and types of abrasive disc.
Mirka Abranet® ACE abrasive has been developed for those tougher and more demanding sanding applications. Due to its optimised net construction and ceramic grit, it gives a superior cutting performance on hard wood (for example, beech and oak) as well as fast cutting on various solid surface materials. Abranet® ACE is also excellent for all paint sanding applications, with optimal performance and an enhanced disc life.
The anti-static extraction hose has a 27mm outlet, is 4m in length and is supplied with adaptor. The swivel exhaust outlet on the machine is also antistatic. One of the key features of the Mirka DEROS is the Bluetooth low energy technology, which helps you to reduce your exposure to vibration.
The DEROS is supplied in a stacking storage case with 125mm and 150mm backing pads. This package also includes 200 Abranet® ACE abrasive discs 150mm diameter 50 x 80G, 50 x 120G and 50 x 180G, and 50 x 240G and the anti-static 4m extraction hose.
2+1 Extended Warranty on Mirka sanders, registration required within 30 days.
- Low profile with low weight, use in any position
- Use 125mm or 150mm pad - supplied with both
- Soft start and electronic pad brake for controlled sanding
- Switch on then control with variable speed lever on top of machine
- Backing pads have multi-hole design to move dust effectively
- 2+1 Extended Warranty on sanders, registration required
- Supplied with 125mm and 150mm quick change pads and storage case, 200 Abranet ACE abrasive discs 150mm diameter 50 x 80G, 50 x 120G, 50 x 180G and 50 x 240G, anti- static 4m extraction hose with adaptor.
