The NVQS350B-21 low noise vacuum is tough - very tough. This is the model that has proved it can outlast the rest in the most arduous of applications. The all-steel power head is low noise and, with the new ECO high efficiency motor, it is just about as good as you can get, even down to the Nucable plugged replaceable cable system and an air blower facility. Filtration is to the Tritex standard with the added advantage of giant HepaFlo 15 litre dust bags and easy, clean emptying. The all-steel container is mounted on, but removable from, a rugged wheeled tubular chassis which really does give it 'go-anywhere' mobility. A full range of 32mm accessories of an equally high standard is supplied for all cleaning applications.
Industrially rated, 580W ECO high efficiency motor, low power usage
Triple stage filtration down to 0.5 micron
Microtec noise reduction system
Stainless steel tubes and comprehensive cleaning kit
Rear exhaust for use as blower unit
Super strong chassis with large wheels for easy mobility
