Osmo Polyx Hard-Wax Oil
- Made from natural vegetable oils and waxes
- Resistant to wine, beer, cola, fruit juices, tea, coffee and more
- Clear Gloss, Satin, Matt or Raw finishes
- Brushes or rollers cleaned with white spirit
- Coverage 24m² per litre each coat
- Drying time 8-10 hours
Hermes RB 406 J Flex Ultimate Abrasive 100mm x 1m (Pkt 5) - MixedFrom £30.98 £25.82
Osmo Polyx Oil is a professional finish suitable for all wooden floors including solid wood flooring, laminated flooring and cork floors. It can also be used on slate, screed, terracotta and a range of other unglazed tiles. Polyx Oil is also well suited for the treatment of furniture, kitchen worktops, doors, MDF, oriented strand-board as well as other types of particle board.
Osmo Polyx Oil provides a finish that is hard-wearing and extremely tough. It is water repellent and dirt resistant. The finish is impervious to wine, beer, cola, coffee, tea, fruit juices, milk and water etc. when dry. Polyx Oil is based on natural vegetable oils and waxes; is micro-porous and does not crack, flake, peel or blister. It is an ideal treatment even in rooms with high humidity but it should be noted that oiled or waxed surfaces should not be cleaned with a steam cleaner or mop.
Osmo Polyx Oil Raw, helps to retains the untreated appearance of timber by using a small amount of white pigments to neutralise the permanent 'wet-look' that develops after application of a clear finish.
Available in Clear Gloss (3011), Satin (3032), Matt (3062) or Raw (3044) and in a range of sizes.
Application Method | Brush \ Rag or Cloth |
Clean Up | White Spirit |
Coverage | 24 m² per litre |
Drying Time | 8 to 10 hours |
Usage | Interior |
