PEANUT® 2 Router Jig
- Foolproof router jig with complete easy to follow instructions
- PEANUT®2 system creates secure, strong joints
- For use with 1/2" hand-held router and drill
- Self-clamping invisible connection for 90° and 45° joints
- Pulls parts together, produces incedibly strong joints
- Joints can be taked apart and reassembled many times without loss of strength
The ultimate in self clamping, invisible connectors
Designed with the woodworking and furniture industry in mind, the Peanut Connecting System produces a wide variety of 45° and 90° joints quickly and efficiently using a ½" router and a drill.
Making joints with the PEANUT® jig is quick and efficient, resulting in a strong, rigid connection. Anyone with a 1/2" router and a drill can produce a wide variety of cabinet joints quickly, 90° and 45° with spot-on accuracy everytime. The PEANUT® 2 jig is just about as foolproof as a jig can be complete with easy to follow instructions.
The PEANUT® 2 system creates secure, strong joints and enables cabinets and furniture to be taken apart and reassembled many times without loss to the joint strength, making it ideal for flat-packing. The PEANUT® 2 router jig includes jig body (740mm x 190mm x 12mm) and fence (740mm x 110mm x 20mm), 4 x PEANUT® slot guide inserts,1 x drilling guide bush, 1 x 6mm HSS drill bit with stop, 1 x low profile router guide bush, 4 x M6 hex head bolts and 1 x nylon carry case.
