PROXXON 60/E Mill-Drill 12V & NG 2/S Mains Adaptor
720638
From £64.98 £54.15
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Low Stock - Ready to dispatch
  • PROXXON MICROMOT 60/E Mill/Drill Unit 12V
  • Variable speed: 5,000 to 20,000rpm
  • Soft grip nosepiece for comfort
  • Slim, easily handled and lightweight (230g)
  • Smooth running, balanced, quiet motor
  • High quality steel collets ensure accurate clamping
  • Supplied with 6 collets: 1, 1.5, 2, 2.4, 3 and 3.2mm
  • PROXXON MICROMOT NG 2/S Mains Adaptor
  • Tough heat resistant NORYL casing
  • Foldable rest for MICROMOT tools
Package deal comprises a PROXXON MICROMOT 60/E Mill/Drill Unit 12V and a PROXXON MICROMOT NG 2/S Mains Adaptor.
The MICROMOT 60/E is a variable speed machine from 5,000 to 20,000rpm with high torque at lower speeds. With a diameter of only 35mm and its low weight, the PROXXON MICROMOT 60/E has great balance and is easy to manipulate. The soft grip makes for convenient, safe handling and a tool that is a joy to use. The balanced motor with ground spindle and collar bearing make this a very smooth running machine.
This versatile workhorse lets you engrave, cut, sand, polish, grind and more. Whether you are a model builder, detail carver, tool and die maker, jeweller or artist, you will find the MICROMOT 60/E invaluable. The wide range of PROXXON bits available let you work on steel, wood, non-ferrous and precious metals, glass, ceramics, plastics and stone.
It comes with a set of 5 high-quality MICROMOT steel collets (1 each of 1, 1.5, 2, 2.4, 3 and 3.2mm). These hardened steel collets have 3 slits. The design results in an increased bearing surface, ensuring positive and accurate clamping of even the smallest shanked bits.
The tool has a standard 20mm collar for stationary use with the PROXXON drill stands MB 140/S and MB 200 as well as in the universal holder UHZ.
The MICROMOT NG2/S mains adaptor has a heat resistant NORYL casing, which is a necessity for transformer enclosures. The red LED indicates readiness for use and the PTC (Positive Temperature Coefficient) element prevents overload of the unit. A foldable tool rest provides a secure place for keeping the MICROMOT 60/E at the ready.
Warranty 2 Year Warranty
