PROXXON 60/EF Mill/Drill 12V & NG2/S Mains Adaptor
720636
From £64.98 £54.15
6 Reviews
  • PROXXON MICROMOT 60/EF Mill/Drill Unit 12V
  • Keyless chuck 0.3 – 3.2mm for quick bit changes
  • Variable speed: 5,000 to 20,000rpm
  • Soft grip nosepiece for comfort
  • Slim, easily handled and lightweight (230g)
  • Smooth running, balanced, quiet motor
  • PROXXON MICROMOT NG2/S Mains Adaptor
  • Tough heat resistant NORYL casing
  • Foldable rest for MICROMOT tools
Package deal comprises a PROXXON MICROMOT 60/EF Mill/Drill Unit 12V and a PROXXON MICROMOT NG2/S Mains Adaptor.
The MICROMOT 60/EF is a variable speed machine from 5,000 to 20,000 rpm with high torque at lower speeds. It comes with a keyless chuck with a range of 0.3 to 3.2mm. This offers fast bit changes and the ability to use very fine micro-drills. With a diameter of only 35mm and its low weight, the 12V PROXXON MICROMOT 60/EF has great balance and is easy to manipulate. The soft grip makes for convenient, safe handling and a tool that is a joy to use. The balanced motor with ground spindle and collar bearing make this a very smooth running machine.
This versatile workhorse lets you engrave, cut, sand, polish, grind and more. Whether you are a model builder, detail carver, tool and die maker, jeweller or artist you will find the MICROMOT 60/EF invaluable. The wide range of PROXXON bits available let you work on steel, wood, non-ferrous and precious metals, glass, ceramics, plastics and stone.
The tool has a standard 20mm collar for stationary use with the PROXXON drill stands MB 140/S and MB 200 as well as in the universal holder UHZ
The MICROMOT NG2/S mains adaptor has a heat resistant NORYL casing, which is a necessity for transformer enclosures. The red LED indicates readiness for use and the PTC (Positive Temperature Coefficient) element prevents overload of the unit. A foldable tool rest provides a secure place for keeping the MICROMOT 60/EF at the ready.
4.80 6
