PROXXON Battery Powered Tube Belt Sander RBS/A (Body Only)
105049
From £145.98 £121.65
1 Review
Out of Stock
  • For cleaning, or satin finishing pipes and tubes
  • Reduces tedious, time-consuming hand finishing
  • Head angles up to 60° for work in tight spots
  • Uses 10 x 330mm sanding belts
  • Cordless freedom with 2.6Ah, 10.8V Li-Ion battery
  • Variable speed for wide variety of applications
  • Soft component grip for comfort and control
  • Supplied complete with accessories
  • Body only tool supplied without battery or charger in cardboard box
The PROXXON RBS/A Tube Belt Sander is perfect for grinding, cleaning or putting a brushed finish on pipes or tubes. It is particularly effective in places that are difficult to reach using "regular" power tools. The RBS/A greatly reduces time-consuming refinishing by hand in restricted areas. It is suitable for sanding, brushing and cleaning steel, non-ferrous metals and especially stainless steel.
It features continuously variable speed control (full-wave electronics) for constant speeds under load. Motor power is transferred to the planetary gearing, contained in robust die-cast aluminium housing. The head can be angled by up to 60° at the push of a button. There is a dust extraction outlet for connection to a vacuum cleaner for clean working. The main body of the machine is glass-fibre reinforced polyamide with a rubberised grip for comfort and greater control.
Supplied with 4 abrasive belts (2 x 180g, 2 x 280g) and 2 satin-finishing belts.
Please note, this is a body only tool supplied without battery or charger in a cardboard box.
4.00 1
