PROXXON BBS/S Compact Belt Sander
702042
From £156.98 £130.82
4 Reviews
In Stock - Ready to dispatch
  • Small compact sander for modelling
  • Fine adjustment for the rollers prevents belt run off
  • 40mm wide
  • Spring clamping system for easy tool-less replacement of belts
  • Supplied in a sturdy plastic carrying case with five each 150g and 240g sanding belts and screw clamp
Compact, light and well balanced, (only 175mm long) with super driving power for maximum sanding performance! The 40mm wide sanding belt is located flush on the left side to allow surfaces to be sanded "right down to the corner". A fine adjustment for the rollers prevents run off on the side. Spring clamping system for easy replacement of belts without tool.
Supplied with a sturdy plastic carrying case together with 5 each 150 grit and 240 grit sanding belts and a clamp for stationary, inverted use.
4.00 4
