PROXXON Battery Powered Random Orbital Polisher EP/A
107293
From £229.98 £191.65
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
  • Perfect for finishing spot repairs on bodywork
  • Swirl free fine finishes on paintwork or bare metal
  • 11mm random orbit stroke with variable speed
  • Powerful quiet motor and planetary gears
  • Supplied in carry case with wide selection of accessories
  • Includes 10.8V, 2.6Ah battery and fast charger
This cordless, random orbit polisher makes short work of adding finishing touches to spot repairs on bodywork. The 11mm stroke of the polisher results in a gleaming swirl free polished finish on painted and uncoated metal surfaces. The unit features continuously variable speed control 1,100 to 2,600rpm. The balanced special motor is powerful and long-lasting.
The EP/A has a quiet planetary gear in die-cast aluminium housing. The main body is glass-fibre reinforced POLYAMIDE with a soft grip insert for comfort and control. Overall length 305mm, disc size 30mm or 50mm. It comes with a 10.8V, 2.6Ah battery and rapid charger.
Supplied in a high-grade polypropylene storage case with the following accessories: Rubber backing disc with hook and loop fastening, polishing sponge (medium hard), lambswool polishing disc, polishing felt (medium hard), 12 sanding discs K 2000, microfibre cloth and spanner for tool change.
Warranty 2 Year Warranty
