PROXXON DS 230/E Scroll Saw
- Variable speed
- Blade wear compensation
- Integral dust blower and dust extraction port
Customers Also Bought
Designed with model making and fine detail work in mind, this lightweight scroll saw 'ticks all the boxes' in the 'must have' list. Accurate, easy to use, variable speed, blade wear compensation / length adjustment, adjustable blade guide / hold-down, integral dust blower, dust extraction port. A surprisingly robust and generous table (160 x 160mm) is fitted with a calibrated rip fence and slide mitre fence, this surmounts a sturdy ABS base with a side door for easy access to the bottom blade clamp assembly, the whole supports the die-cast aluminium saw frame with a throat of 300mm and a simple but very effective tensioning head with integrated blower. Takes standard unpinned scroll saw blades. Supplied with an assortment pack of Swiss made, Pegas blades.
- Variable speed
- c/w calibrated rip fence and slide mitre fence
