This package comprises the PROXXON FET Table Saw and a 80mm T36 TCT Saw Blade.
A saw designed for precise, straight cuts, with a height adjustable and tilting saw blade, up to 45°. It is made for the fine mechanic, model builder, mould making, toy manufacture, architect, model carpenter and fitter. A variety of optional blades allow it to cut a wide range of materials, such as wood, non-ferrous metals, plastics, Plexiglas, PC cards, foam and many others. All load bearing parts and plane-milled table are made of die-cast aluminium making the FET saw very stable.
The table and drive lift for easy access for cleaning or changing the saw blade. The micro-adjustable, precise cut length stop allows cuts as small as 0.1mm to be made. The saw blade, which can be pivoted by 45°, makes the cutting of double mitres possible when used with the angle stop. The FET is driven by a special DC motor with Optibelt toothed belts connecting it the main ball bearing supported shaft. Standard equipment supplied with the saw includes a 24 tooth hard metal-equipped saw blade 80 x 1.5 x 10mm. A push stick and a non-slotted polycarbonate sawing table inset for tight tolerances between saw blade and table when cutting small parts. The FET has a dust adaptor suitable for connection to a vacuum for dust free working.
PROXXON 80mm T36 TCT Saw Blade
Tungsten Carbide tipped blade for use on hard wood, soft wood, plastics and aluminium.
For precise cuts with a height-adjustable and tilting saw blade
Table and drive can be lifted up for easy access for cleaning or blade changing
Micro-adjustable cut length stop for cuts as small as 0.1mm
Easily stored away when not in use
Milled die-cast aluminium table
The sawblade tilts up to 45°
Special DC motor with Optibelt toothed belts
Supplied with 80mm x 24 sawblade
Push stick and zero tolerance POLYCARBONATE table inset
Dust adaptor for connection to a vacuum
TCT blade for hard wood, soft wood, plastics and aluminium
