PROXXON MICROMOT 60/EF Mill/Drill Unit 12V
105597
From £34.98 £29.15
  5. Half Star
11 Reviews
  • Keyless chuck 0.3 – 3.2mm for quick bit changes
  • Variable speed: 5,000 to 20,000 rpm
  • Soft grip nose-piece for comfort
  • Slim, easily handled & lightweight (230g)
  • Smooth running, balanced, quiet motor
  • Requires MICROMOT 12V mains adaptor
The MICROMOT 60/EF is a variable speed machine from 5,000 to 20,000rpm with high torque at lower speeds. It comes with a keyless chuck with a range of 0.3 to 3.2mm. This offers fast bit changes and the ability to use very fine micro drills. With a diameter of only 35mm and its low weight, the 12V PROXXON MICROMOT 60/EF has great balance and is easy to manipulate. The soft grip makes for convenient, safe handling and a tool that is a joy to use. The balanced motor with ground spindle and collar bearing make this a very smooth running machine.
This versatile workhorse lets you engrave, cut, sand, polish, grind and more. Whether you are a model builder, detail carver, tool and die maker, jeweller, artist etc, you will find the MICROMOT 60/EF invaluable. The wide range of PROXXON bits available lets you work on steel, wood, non-ferrous and precious metals, glass, ceramics, plastics and stone.
The tool has a standard 20mm collar for stationary use with PROXXON drill stands MB140/S and MB 200 as well as in the universal holder UHZ. The machine requires a suitable mains adaptor, we recommend MICROMOT mains adaptors NG 2/S, NG 2/E or NG 5/E.
Note:
The speed control of our 12 volt devices only works when operated via nonstabilised power supply units (e.g. all MICROMOT mains adapters). Connection to stabilised power supply units is possible. However, the devices will then operate with maximum rotational speeds (also applies to operation with batteries).
Warranty 2 Year Warranty
4.70 11
