The Complete Mill/Drill System is great value. The complete system consists of: BFW 40/E Mill/Drill Motor and Controller, BFB 2000 Mill/Drill Stand, KT 150 Compound Table & Step Clamp Set.
The BFW40/E drill head with its triple bearing spindle giving superb accuracy and vibration free operation. The power controller gives spindle speeds from 900-6000rpm with full torque control. A set of 6, triple slit, hardened collets from 2.3-6mm is supplied.
The BFB 2000 Drill Stand has a precision milled dovetail slide which may be tilted through 90 degrees, a fine feed selector, depth gauge and rack and pinion down feed. This stand will take all drills and routers with a 43mm spindle collar.
The KT 150 aluminium die cast compound table has a travel of 150mm both ways, graduations of 0.05mm and 3 machined T slots for fastening machine vices and clamps. Suitable for milling, routing or slotting of steel, non-ferrous metals, plastics and wood.
The Step Clamp Set is a 2 clamp set which fits the KT 150 table directly and is ideal to hold the work piece securely in place.
For precision work this PROXXON Mill Drill kit would be very hard to beat, made in Europe by the most respected name in model making equipment.
Very high accuracy and vibration free running
Able to carry out horizontal drilling or machining
Compound table gives precision work piece control
Superb motor control allows the cutting tool to work effectively
Very versatile, the ultimate machine for model making
