PROXXON PS 13 Pen Sander 12V DC
- PROXXON reliability
- Durable DC motor
- Tough glass fibre reinforced Polyamide casing
- Reaches awkward to get at areas
- 8,000 linear strokes per min (2.5mm stroke length)
- Mains adaptor of at least 12 - 18V DC is required, power supplies NG2/E or NG5/E recommended
The PS 13 Pen Sander from PROXXON is a great tool for the model maker and miniaturist. It is ideal for working on surfaces in recesses, slots and other awkward to get at areas. The durable special DC motor is housed in a glass fibre reinforced polyamide casing and is only 160mm long. The unit features a sanding stroke with a linear action, not rotational. Supplied with four sanding arbors with straight shanks and four angled (all different shapes) as well as three sheets of pre-profiled self adhesive sanding pads. The sheets are of grits 180, 240 and 400 with five of each shape per sheet.
N.B. A mains adaptor of at least 1.0A at 10-18VDC is required. We recommend PROXXON power supplies NG2/E or NG5/E.
Corded or Cordless | Corded |
EAN Barcode | 4006274285941 |
Model | PS 13 |
Nett Weight | 0.13 kg |
Stroke Length | 2.5 mm |
Stroke Rate | 8,000 /min |
Voltage | 12 V |
